Pre fractionization- CHCl3/MeOH, phenol
Posted: Mon Dec 14, 2009 7:06 pm
I am trying to isolate a few basic peptides between 3-8,000 Da from brain tissue. I have previously extracted lyopholized tissue with 90/10 MeOH/acetic acid, centrifuge, evaporate supernatant, then put through C4 SPE. However, I'm looking into additional ways to clean up the sample before LC.
Chloroform/MeOH is attractive since it might minimize acidic protease digestion (that may occur with acidic methanol), however, use of CM seems a little unorthodox (compared to widely used MeOH/HOAc)
Does anyone have experience using various extraction protocols with organics, such as chloroform/MeOH, or phenol, in attempts to remove as much non-specific protein/cell constituents as possible before multi-demensional HPLC?
Would use of such organics be useful for selectively separating higher MW proteins from peptides?
