Getting rid of artifact on PLRP
Posted: Sat Dec 12, 2009 8:48 am
by DJ
It has been suggested that HPLC columns be conditioned by repeated injections of an inexpensive (sacrificial) protein (to block sites on column/hardware that would otherwise irreversibly bind low-abundant sample).
I used beta lactoglobulin to condition a 1000 A 1 x 150 mm PLRP column. I almost certainly injected too much, and now I cannot get rid of it. I have done countless up-down gradients (5-60++% MeCN/0.1% TFA) and back flushes with no luck. I've changed pre-column frit, and connections. A blank run yields a super clean baseline plus this artifact (which shows up as a beautiful looking peak eluting at approx the same MeCN%).
The size of the peak decreases little, if any, with successive blank gradients.
Could this protein have precipitated at the inlet frit, causing it to bleed off over time?
Posted: Sat Dec 12, 2009 9:42 am
by HW Mueller
Are you sure that the peak is protein?
Posted: Sat Dec 12, 2009 8:50 pm
by DJ
I'm almost certain the peak is protein. *only* peptide/ protein samples have been injected on that column. The artifact absorbs at 220 as well as 280 nm.
Posted: Sat Dec 12, 2009 8:55 pm
by DJ
Does it sound as though the material is located on the column, or at the frit?
I've gathered the following cleaning protocols:
1 M NaOH
1 M HNO3/IPA (50/50)
70% HCOOH (A) and IPA (B), gradient from A to 100% B.
40/40/10 MeOH/chloroform/1% aqueous HCOOH, with repeated injections of concentrated HCOOH
Assuming the contaminant is beta lactoglobulin, which would be best?
Any problem introducing HNO3 to the support with aromatics?
Posted: Sun Dec 13, 2009 10:47 am
by HW Mueller
It looks like you are introducing the stuff with each injection. A deposited source should decrease with the number of blank injections, unless you have an endlessly large deposit. Absorbance at 220 and 280nm does not prove that it´s a protein, on the other hand, it is also possible that the blanks are contaminated with a protein.
Where did you find these cleaning protocols? Your column is not silica based?
Did you get a "clean" baseline before you injected the protein?
Posted: Sun Dec 13, 2009 7:20 pm
by DJ
I've ruled out mobile phase contamination since freshly prepared 0.1% TFA, MeCN (using HPLC water, TFA) did not change things.
I haven't done a single injection on this column since the original beta lactoglubulin several blank runs ago. I think it -is- an endlessly large deposit.
The PLRP (polystyrene divinylbenzene) column is not silica based, which should permit a more aggressive cleaning protocol than silica-based RP columns. I think this is what I will have to resort to.
Posted: Sun Dec 13, 2009 8:20 pm
by Uwe Neue
What is the UV spectrum of DVB?
Posted: Sun Dec 13, 2009 8:26 pm
by DJ
From quick google search.. not sure how reliable..
Posted: Mon Dec 14, 2009 9:37 am
by HW Mueller
If DVB = divinylbenzene then Uwe is getting at bleeding as possible source. I also googled and found this:
http://135.196.210.195/suppdata/CC/b8/b ... 17598e.pdf
This is totally different than the spec above, it has strong absorbance at 220 and something at 280 also, as I expected.
Nevertheless, your "experiments" do not rule out contamination of the blanks you injected.
Posted: Mon Dec 14, 2009 6:45 pm
by DJ
By "contamination of the blanks" are you referring to mobile phase impurities?
Leaching of the polymeric support is not something I had thought of. If this were happening, would you expect to see single or multiple peaks?
Posted: Tue Dec 15, 2009 9:43 am
by HW Mueller
The "dirt" could come rom anywhere. Very often it is introduced by a systematic/consistent carelessness.
In any case, the first thing to do is run a UV spectrum of the peak, it may say something about the source.
On bleeding from polymer columns, Uwe would be more qualified to give an answer.
Posted: Tue Dec 15, 2009 5:55 pm
by Uwe Neue
Bleeding from the polymer is likely to involve a whole slew of complex structures. I do not expect multiple peaks, but one broad peak.
