BP question...changing a BP method
Posted: Fri Dec 11, 2009 11:31 am
To whom it concerns,
I have two questions and should be considered independent of each other.
1. In the BP it states that minor adjustments can be made to a liquid chromatography method...example :column length +/- 70%, particle size: maximal reduction of 50%, no increase permitted. What happens if i go out side these limits? for example on one parameter? Does the method therefore become no longer a BP method and therefore would be considered a new method? requiring full validation?.
2.If a method states the use of potassium dihydrogen phosphate for buffer/Mobile phase make up. Can you change buffer salt to another?...and if so, is this then considered an entirely new method and no longer represents the BP method?
Regards
Seamus Moroney
Regards
Seamus Moroney
