Colum: DB-624 (30 x 0.32 x 1.
Inlet: 170ºC ; split 1:10
Detector: FID 260ºC
Tª program: 40º(5min) at 10º/min to 200º(0min) at 20º/min to 240º(0min) (total: 23min)
Carrier: He
Flow: 1.5ml/min (constant)
Sample
- Vial 20ml
- 2g NaCl
- 10ml sample
- 5 ul ISTD (1-Cloropentane solution in MeOH; 8ng/ul)
Autosampler: CTC CombiPal
- Syringe Tª = 75ºC
- Incubation sample: 70ºC; 30min; agitation 500rpm.
The elution order are : benzene (tr = 9.4), ISTD (11.
, Toluene (12.2), Clorobenzene (14.1), etilbenzene (14.3), m and p-xylene (14.5), o-xylene (15)
m-xylene and p-xylene coelute in a 624 column. If you need diferenciate it you can use a wax column. But in a wax column the benzene elute near the MeOH.
If you need more information...
good luck
