help with Flash or Column Chromatography (instead of HPLC)
Posted: Tue Dec 08, 2009 6:09 pm
Hello everyone.
First off let me say thank you for all the support that has been available to me so far. Now it is time for me to stop silently monitoring and ask a question:
My lab partner "Zhensr" and I are purifying meta-Cresol Purple, an indicator dye used in spectrophotometric pH measurements. Through advice from this forum we were able to purify it using a SIELC Primesep B2 column and 70% ACN 30% H20 with TFA. The prep-scale method uses too much ACN (30mL/min for 45 min X five runs for only a few 100 mg isolated product).
I have been researching 'flash or column chromatography' but it is a new topic to me. I am not sure how to choose a proper solvent system or column packing material for prep-scale purification of the dye using flash chromatography. Any comments/input would be very much appreciated.
Thank you.
MP
Thank you.
MP
