[Chromeleon] External standards
Posted: Mon Dec 07, 2009 6:42 pm
Hello my Chromatographical Friends,
Since a few days I have started working with Chromeleon 6.8 It takes some effort to make the transition from working with Atlas and ChromQuest to Chromeleon, but it seems I'm getting there.
There is just one thing I haven't been able to figure out. I usualy work with an external calibration sequence and I want to use this sequence for newer sequences with unknowns in them. What I do now is that once the sequence is finished I copy the standards + the raw data from the original calibration sequence in the unknown sequence. With that copied data I can quantify the peaks in the unknowns.
From the manual I understand that it is possible to use the external calibration sequence without copying the data, but how to do this? It has something to do with the 'Fixed'-calibration option in the QNT-method, but I don't know how.
Thanks!
Maurice
Thanks!
Maurice
