Pse HCl USP method chemistry help please
Posted: Thu Dec 03, 2009 5:54 pm
I need help with a column/mobile phase/api chemistry interaction theory involving the USP hplc method for pseudoephedrine hcl. This is a current debate in my lab as we attempt to verify and optimize the method for our use.
The column is an eclipse xbd phenyl and the mobile phase is a 90/10 triethylamine buffer pH=6.8/methanol.
I was not able to achieve the resolution I needed so I added water through the switching valve that ended up in 97/3 (buffer/meoh)/water. This decreased the ratio of triethylamine to methanol. In doing this, the resolution was increased and the peak shape held up.
My hunch to do this was based on my understanding of the chemistry involved with the amine. The amine competes with the pseudo for silica binding sights. In adding water, I decreased the amount of the triethylamine (minor component), thus increasing the probability of the pseudo interacting with the silica and increasing retention.
Is this what is going on and is this why I was able to achieve better resolution?
Another chemist working on this did the same thing, but instead of adding water, she just added more buffer in the same amount as I added water. I said that with the ratio of triethylamine to meoh increasing, she would see worse resolution and peak shape. This is exactly what we saw. Of course she disagrees with this explaination of the result and is pushing to purchase more columns.
Can somebody help me with this chemistry problem? Thanks a bunch.
