5890 FID assembly compatible with a 6850 GC?
Posted: Mon Aug 01, 2022 2:57 pm
by lespaul
Hi everyone,
We have a Agilent 6850 GC with a TCD and I would like to replace with an FID from a 5890. Does anyone know if this is compatible?
The FID assembly from the 5890 has all the connector, tubing, etc. But I'm not sure if I need a special card/signal board to make this work or if I can use the existing on the 6850 for the TCD?
Thanks in advance
Re: 5890 FID assembly compatible with a 6850 GC?
Posted: Mon Aug 01, 2022 8:03 pm
by AICMM
No. You need the electronics that run the FID and in this case it will also probably recognize the need for an EPC specific to the FID. So no.
Best regards,
AICMM
Posted: Fri Aug 05, 2022 6:41 am
by antonk
Looks like 6890 and 6890,6850 have the same FID
https://www.restek.com/row/products/acc ... lies/6207/
