silylation slow
Posted: Wed Nov 25, 2009 10:15 am
developing a GC-method for alkanolamines I have the following problem: for better chromatography I have derivatize them.
I use MSTFA with 10 % TMCS to make a silylation. The problem is, the reaction is rather slow, I have done some tests and measuerd the peaks after 2 up to 6 hours reaction time at 80 °C, the peak is still growing at the end of the time. The maximum is achieved when I measure the next day and the vials stood at room temperature over night. This is not practical solution.
The effect is different for different amines, so an internal standard would not help.
I added the TMCS as the reaction is better then, I tested at 70 °C and 80 °C, the increasing temperature has not such a big impact.
Has anyone another idea to boost this reaction?
Thanks a lot,
Beate
Thanks a lot,
Beate
