waters 2695 column diverter vs column switch
Posted: Mon Jul 25, 2022 1:16 pm
We have a 2695 with a column heater and column switch. I want to use the column switch as a diverter valve after the column to spare our CAD from our sample matrix necessary for sample chromatography. I tried to create an EVENT in Empower to change between two columns in the middle of the run, but it didn't work. Does anyone have any thoughts on how to do this?
Similarly, if you were running samples all night and wanted to change to a different column automatically, how would you do this in Empower? I know that I can physically change the switch position from the front panel, but I don't want to be there at 3 am to do this.
