Separate enantiomers and disastereomers in single run?
Posted: Tue Nov 24, 2009 11:18 am
by MS_chrom
Anyone ever had experience separating all enantiomers and diastereomers in a single run?
Is it feasible? TIA
Posted: Tue Nov 24, 2009 2:48 pm
by bisnettrj2
Separate all enantiomers and diastereomers of what, exactly? To start, check out
http://www.chiraltech.com/col_overview.asp
Not an endorsement, just the first result Google gave.
Posted: Tue Nov 24, 2009 3:34 pm
by grzesiek
"Is it feasible?" - yes
Posted: Tue Nov 24, 2009 7:04 pm
by HPLCCONSULT
Just as "grzesiek" said. Yes, you can, but it often is not the best solution as chiral columns tend to be very poor at resolving achiral species apart. Two different methods/columns are preferred.
*However, having said that, our lab has often separated the enantiomers of compounds with multiple chiral centers (3x) all using one method/column so that is an example of both being done at the same time. In general, I would not recommend it (w/o knowing all of the details of your samples and impurities) for the reason that it is usually poor at resolving achiral species.
Posted: Tue Nov 24, 2009 7:08 pm
by JA
If this is a poll my answer is yes, to both questions.
Posted: Tue Nov 24, 2009 10:23 pm
by shahis77
YES it is possible
