Need Help - Method Validation for Qualitative GCMS analysis
Posted: Sat Nov 14, 2009 6:05 am
Hi all,
I am planning for a method validation project but in terms of Qualitative analysis for GCMS.
This project basically involves using the GCMS to identify Pharmaceuticals. (The ones that are volatile enough to be tested in GC).
I will use Library search to identify my unknowns. then I would compare their retention time to the Reference standards that is available in our lab.
After going through some guidelines for Method validation, the ones I found so far mostly emphasize method validation for Quantitative analysis.
So I was wondering if anyone knows any other useful guidelines I could use that emphasize more on qualitative analysis especially for GCMS.
In terms of reference standards for qualitative, does the reference standards need to be a certified ones? or are analytical grades (with CoA) sufficient for this purpose?.
Tarapan
Tarapan
