Swagelok carrier gas valves- lubricated or non-lubricated?
Posted: Tue Jun 14, 2022 7:30 pm
Hello, I'm planning on installing 3-way ball valves just upstream of my GC-MS carrier gas inlets to allow for toggling between helium and nitrogen. Swagelok valves typically come pre-lubricated, though they do make a special non-lubricated version of all of their ball valves which is more expensive and has lower pressure ratings. I don't know if the silicone-based lubricant on their "normal" valve assemblies is something to worry about or not. Agilent technicians I spoke to did not seem to be aware there are versions with and without lubrication and defaulted to recommending the non-lubricated version because obviously, lubricants could be a source of contamination. Does anyone have any real-world experience with this?
