Ultimate 3000 Dionex UHPLC - No flow from B or Loading Pump
Posted: Sat Jun 11, 2022 5:38 pm
System - Dionex Ultimate 3000 UHPLC
Software - Chromeleon, Hystar
1. Purged A and B for 30 min.
2. Run left block only, 0.6 uL/min flow gave 7.5 bar with 89.1% A and got output from the mixing valve.
4. Purged B 10-mLs collected in 20 minutes collected purge in graduated cylinder.
5. Purged B second time, 30 minutes.
6. Tried to re-run B but still 0.9 bar and no flow from the outlet.
7. Increased flow to 0.9 uL/min still no flow, 1.3 bar.
8. Increased flow to 1.5 uL/min still no flow, 1.9 bar, no outlet.
9. Increased flow to 1.5 uL/min still no flow, 99% B, 0.5 bar, no outlet.
10. Switched B to A, purged 30 minutes.
11. Now B is A flow to 1.5 uL/min still no flow, 99% B, 0.7 bar, no outlet.
12. Got output from the pump line going into the mixer.
13. No outflow from Loading Pump.
Does anyone have an explanation or suggestions for things to try?
Many thanks
Many thanks
