Unexpected: Phenomenex Rezex RHM-Monosaccharide column spike
Posted: Mon Apr 25, 2022 5:46 pm
Hi everybody - Happy Monday.
I've been able to fix an old Shimadzu UPLC and C18 column with the forum's help. You all are awesome. Now I'm trying to sort out an issue with another Shimadzu UPLC but using a phenomenex rezex RHM-monosaccharide column for C6 and C5 sugar and acid-sugar detection. I washed it with 0.025 M H2SO4 at a flow of 0.2 mL/min for about 24 hours at 85-degrees C. Swapped it over to nano pure filtered water until it equilibrated. Let it run for another 4 hours. The baseline looked pretty solid. I loaded a few known samples (Glucose, Xylose, Erythrose) turned the flow up to 0.5 mL/min and dropped the temp to 65-degrees. RID is at 65 as well. NO UV detection in the method. Samples run until the first peak, then - I'll attach a screen shot here... What could be making the know standard jump like this? Pressure is all good.
Thoughts appreciated!!
Best,
Carbon
Best,
Carbon
