ADVANCEMENT IN FLUE GAS FLOW MONITORING
Posted: Tue Apr 19, 2022 3:10 am
by leomiinstruments
The efficient operation of today’s power plant depends largely upon accurate & repeatable measurement of primary and secondary airflow to coal mills, flue gas recirculation flow, overfire air flow, airflow to individual burners, etc.
Flue gas or Stack gas emission flow rate measurementis nowadays important for quantifying emission (CEMS) for environmental reporting for Govt. Authorities for pollution control. Flue gases are gases emitted due to the combustion process due to heating of fuel (liquid or solid or gaseous) & Air with a stoichiometric ratio in:
  • Boiler Heating
    Process furnaces
    FLUE GAS PRODUCTION DUE TO COMBUSTION MAINLY CONSIST OF :
    Nitrogen (N2)
    Carbon monoxide (CO)
    Carbon dioxide (CO2)
    Traces of Sulphur dioxide (SO2),
    Nitrogen oxides (NO, NO2)
    Particulate matters (SPM)
    Moisture
Flue Gases are gases emitted due to combustion process due to heating of fuel (liquid or solid or gaseous) & Air in:
  • Thermal Power Plant
    Steel & Foundries
    Cement production plant
    Chemical & Fertilizer production process plant, many more..
