Can I use NMP as a solvent for RP-HPLC analysis?
Posted: Fri Oct 30, 2009 6:42 pm
by moonchips
Greeting,
I would like to know if it is OK to use NMP as a solvent for RP-HPLC analysis with 5uL injection.
Is it going to ruin the C18 stationary phase? I do observe a huge peak at void.
thanks
Posted: Fri Oct 30, 2009 6:43 pm
by moonchips
and what about DMA?
Posted: Sat Oct 31, 2009 9:06 am
by danko
I wish I knew what “NMPâ€
Posted: Sat Oct 31, 2009 10:25 am
by bisnettrj2
For starters, I have no idea if you can use either solvent in RP-HPLC. My guess is probably "it depends". More info on either solvent...
Google tells me NMP is N-Methylpyrrolidone, and DMA is Dimethylacetamide.
NMP "is the lactam of 4-methylaminobutyric acid and a very weak base. NMP is a chemically stable and powerful polar solvent. These characteristics are highly useful in a variety of chemical reactions where an inert medium is of concern. Despite the stability of NMP, it can also play an active role in certain reactions: hydrolysis, oxidation, condensation, conversion with chlorinating agents, polymerization and o-alkylation, and related reactions."
http://www2.basf.us/diols/bcdiolsnmp.html
DMA is "used as a solvent for polyacrylonitrile, vinyl resins, cellulose derivatives, styrenes and linear polyesters. Also used as a catalyst and solvent in elimination, halogenation, cyclization, alkylation, interesterification, and phthaloylation reactions."
http://www2.dupont.com/Products/en_RU/D ... de_en.html
I assume more info from moonchips may be necessary (for the smart guys on the forum):
Column type? Perhaps manufacturer, packing material, length, I.D., etc?
Other mobile phase constituents?
pH?
Temperature?
Detector?
Analyte type/names?
I found one aplication note for a "N-Methylpyrrolidone (NMP) + 0.1M LiBr mobile phase" in the analysis of 'Poly (Vinylidene Fluoride)' on 'Jordi DVB GBR Mixed Bed Linear' column, 500 x 10mm ID
http://www.gentechscientific.com/an59.htm
I found an abstract more a method using DMA as a constituent of a mobile phase on a C8 column "for the sample preparation and handling for the determination of amino acids, monoamines and metabolites from microdissected brain regions of the rat".
http://www.medscape.com/medline/abstract/9698226
Mostly, though, it seems these solvents are used in SEC/GPC.
Posted: Sat Oct 31, 2009 12:56 pm
by grzesiek
"I would like to know if it is OK to use NMP as a solvent for RP-HPLC analysis with 5uL injection." - by the things you write I'm guessing you wanna use it as a diluent
The size of the injection does say nothing without size of the column
Taken all into account I personally wouldn't worry about the column
"I do observe a huge peak at void. " - you do inject polar solvent right?
What about dissolving your analytes in these solvents, and then diluting with some other solvent like MeOH/ACN/Water or simmilar to get rid of the huge peak at void?
Posted: Sat Oct 31, 2009 1:02 pm
by bhuvfe
Moonchips,
Do you want to use it as diluent for your samples or in the mobile phase?
It has quite a high UV cutoff so detection by UV might not be the most practical choice ( http://macro.lsu.edu/HowTo/solvents/UV%20Cutoff.htm).
I wouldn't see any problem in injecting it in any HPLC column or using it as
mobile phase till you can stay under the maximum tolerated column pressure and have a decent detector.
Do you plan to use it for non aqueous RP?
http://macro.lsu.edu/howto/solvents/Pol ... 0index.htm
bhuvfe
Posted: Mon Nov 02, 2009 2:27 pm
by moonchips
Sorry for any confuse.
I would like to use them as sample diluent and inject directly onto HPLC.
Column: YMC C18, 100*4.6*5
Temperature: 25
Mobile A: 0.05% TFA
Mobile B: 0.05% ACN
PH: 2
Detection: 240nm UV
analyte: small API with MW about 500 base molecule
injection size: 5uL
Thanks a lot
Posted: Mon Nov 02, 2009 5:18 pm
by bisnettrj2
I would agree with grzesiek then, such a small amount of solvent shouldn't be an issue as an injection solvent. However, I do wonder why you aren't just dissolving your standards/samples in your mobile phase?
Posted: Mon Nov 02, 2009 8:11 pm
by Chromatographer2010
DMAC and NMP help with solubilizing samples in a smiliar fashion to DMSO without the added viscosity.
With silica based C-18 columns like yours they have not caused me any problems in the past and I have seen their use in the literature.
Posted: Mon Nov 02, 2009 8:23 pm
by bisnettrj2
Ah, I see. I'm not a pharma guy, so I learned something today. Yippee!
