Perkin Elmer Clarus 600 GC-MS communication problem
Posted: Mon Mar 07, 2022 4:40 pm
Hi everybody,
our university lab got gifted an old PE Clarus 600 GC with a Clarus 600C MS. I managed to set up everything in our lab but I cannot get the PC to communicate with the system via the TurboMass 4.5 Software. I set up the IP correctly, as I can ping the MS via network drivers, but I get no anwer packages by the ethernet connection from the MS.
Similar problem with the GC. I can start the GC with the attached control display, but no communication with the software via the serial port. I connected the systems, as described in the manual.
Hope you can point me in the right direction.
All the best
D
All the best
D
