Grob Test Mixture reproducibility
Posted: Wed Mar 02, 2022 6:25 am
Hi all,
I met this problem when I tested the reproducibility using grob test mixture (three injections, diluted in DCM). The system I use is a GCxGC-ToFMS.
Some compound like Decane, undecane, Methyl caprate,.. have ~4% RSD
However, octanol, nonanal, 2,6-Xylidine have ~25% RSD
May I ask what could be the problem?
thank you!
thank you!
