Agilent 1100 ALS issues
Posted: Tue Mar 01, 2022 9:41 pm
Hello all,
I am a graduate student attempting to fix the autosampler of an Agilent 1100. I am open to setting up the manual injector as well, but have other issues associated with that.
First to describe the autosampler issues, the unit we are using received a "fan failed" error several weeks ago. We replaced the fan, but the error persisted. When I try to reset the module, I then receive another error on the quaternary pump saying "Unknown error." and also "Initialization error (4)" on the injector. I also tried to reset the injector itself in Diagnoses tools but receive "RA 0000 RSET" as an error.
I tried to set up a manual injector as well, I have a Rheodyne 7725i with the connector cable to the instrument. However, the connector cable has two pins associated and not the remote connecter, so I purchased a D89 connector with the ability to connect the two pins internally. I am unable to determine which slots the pins go into (from 1-9) and also I don't know if once it is working, if a new module will appear, or how to trigger the manual injector to work properly.
Apologies if this is confusing, I can provide photos if needed.
