Chromeleon 7 losed run
Posted: Mon Feb 28, 2022 10:27 am
by lucaelia005
Hello, i wish you can help me I have a big problem with managing files in the chromeleon database. When I delete a chromatographic run file from a folder (by right clicking and selecting "delete"), it disappears completely and it is no longer possible to recover it. It is no longer present in the delete items folder either. is there any way to recover the files so destroyed?
i looked very carefully in both chromeleon recycle bin and windows recycle bin, but it turns out nothing. thank you very much I hope it is possible to find a solution
Re: Chromeleon 7 losed run
Posted: Thu Sep 15, 2022 1:57 pm
by sbrand
Hi
The Chromeleon Help delivers the answer:
The following types of data can be moved to the Deleted Items folder only when they are standalone items in a folder: instrument method, processing method, report template, view settings, spectral library, and electronic report. If they are not standalone items, they will be permanently deleted. Examples of this include:
An injection or a report template associated with a sequence
Cheers,
