Prednisolone and Methylprednisolone separation using NP
Posted: Sun Oct 25, 2009 2:21 am
Can anyone help me out. I have Normal phase HPLC method for separation of Prednisolone and Methylprednisolone and chromatographic condition as below
column : silica column 25cmx4.6mm 10 micron
mobile phase : Butyl chloride : water saturated Butyl chloride : Tetrahydrofuran : Glacial acetic acd : Methanol (475:475: 60:30:35)
Now as per method I suppose to get RRT for prednisolone is 0.7 and for Methylprednisolone is 1.0 but when I injected my resolution soln, i found mehylprednisolne eluated first and prednisolon second. I guess method given in literature seems incorrect internal std i.e prednisolone it should be prednisone because looking at the molecule structure and chemistry, method is purely partition based chromatography and effinity towards stationary phase and t is not pH dependent as both molecule has similar molecules except methyl group. Please suggest my guessing is correct or any other reasons.
