Moving Towards Sustainable Gas Chromatography Laboratories
Posted: Thu Feb 17, 2022 11:02 am
by CF - David Hills
When: On-demand
Helium shortages mean that laboratories will soon need a sustainable alternative to this non-renewable resource. Also, the struggle to maintain a consistent helium supply is causing a drop in productivity in many labs and the cost of helium continues to rise.
Progressing to a more sustainable laboratory is possible by switching to a multi-gas system. Switching to hydrogen, for example, protects laboratories against future helium shortages and is more sustainable because high-purity hydrogen can be generated from water. Hydrogen offers faster chromatographic separations, shorter thermal desorption methods and lower-temperature separations than helium, drastically increasing laboratory throughput, extending consumables’ lifetimes and extending maintenance intervals. Hydrogen also produces the same high-quality data as helium but at a greatly reduced cost.
By watching this presentation you’ll learn about:
  • - The current situation with the global supply of helium
    - The benefits of using hydrogen as a carrier gas
    - Configuring thermal desorption–gas chromatography–mass spectrometry analytical instrumentation to work safely with hydrogen as a carrier gas as well as with helium and nitrogen
    - The pros and cons of different hydrogen sources (bulk supply vs gas generator)
    - Common pitfalls when switching carrier gas and how to avoid them
To watch the presentation click on the link below:
https://webinar.sepscience.com/form/mov ... boratories
