Helium shortages mean that laboratories will soon need a sustainable alternative to this non-renewable resource. Also, the struggle to maintain a consistent helium supply is causing a drop in productivity in many labs and the cost of helium continues to rise.
Progressing to a more sustainable laboratory is possible by switching to a multi-gas system. Switching to hydrogen, for example, protects laboratories against future helium shortages and is more sustainable because high-purity hydrogen can be generated from water. Hydrogen offers faster chromatographic separations, shorter thermal desorption methods and lower-temperature separations than helium, drastically increasing laboratory throughput, extending consumables’ lifetimes and extending maintenance intervals. Hydrogen also produces the same high-quality data as helium but at a greatly reduced cost.
By watching this presentation you’ll learn about:
- - The current situation with the global supply of helium
- The benefits of using hydrogen as a carrier gas
- Configuring thermal desorption–gas chromatography–mass spectrometry analytical instrumentation to work safely with hydrogen as a carrier gas as well as with helium and nitrogen
- The pros and cons of different hydrogen sources (bulk supply vs gas generator)
- Common pitfalls when switching carrier gas and how to avoid them
https://webinar.sepscience.com/form/mov ... boratories
Separation Science/Chromatography Forum/
Analytical Training Solutions
david.hills@sepscience.com
