2 dimensional GCxGC peak broadening/wrap arround
Posted: Sun Feb 13, 2022 9:00 pm
Hi there,
I am working on my project using GCxGC TOFMS
the column set I am using is SLB-5MS/ SLB-50MS. I run the Alkane standard and see very broad peaks in the 2nd dimension, and the peaks are wrapping around.
Does anyone have any idea about what the problem could be?
Thank you!
Thank you!
