Perkin Elmer Clarus 500 from USA to Europe
Posted: Tue Jan 25, 2022 12:39 pm
by greg07
I am writing from Europe. I am using a Clarus 500 split / splitless / FID chromatograph. I want to extend this chromatograph with a second channel, also Split / slpitless / FID. It is not profitable to buy parts separately. I would like to buy a used chromatograph in the USA and rearrange the parts. I have a question, will all internal modules work properly with 230V?
Regards
Re: Perkin Elmer Clarus 500 from USA to Europe
Posted: Thu Jan 27, 2022 5:45 pm
by DR
If the unit you have requires throwing a switch, changing cords and (maybe) changing the fuse on the back panel, then it should be Yes, the internals are the same.
Posted: Fri Jan 28, 2022 12:43 pm
by dblux_
According to "Clarus 500 GC Installation Guide" you only need to "change the wiring on the AC Distribution P.C. board as described in the following procedures".
Procedure is printed on page 85 of above mentioned guide.
https://www.perkinelmer.com/CMSResource ... lation.pdf
So every Clarus 500 GC is suitable for different power supplies around the world. Very convenient, especially for manufacturer.
