Agilent 7890B GC System w/7697A Headspace Sampler, ALS tower
Posted: Sun Jan 09, 2022 9:25 pm
Thanks for taking your time to read my question.
I have an Agilent 7890B GC System w/7697A Headspace Sampler. The transfer line has been integrated into the gas line at the inlet of the GC. I would like to switch over to liquid injections using the ALS tower.
I can remove the transfer line by unscrewing the connection to the GC inlet, but this leaves an opening that prevents the inlet from maintaining proper pressure.
Is there a part number for a fitting that will seal this hole?
Is there a way I can configure the headspace unit to keep the transfer line in place and use the ALS tower for liquid injections?
The instrument is controlled by Empower 3.
I've gotten good advice from this forum in the past, and I'm hoping for more now.
Thanks again for your time.
