(Mass labeled) PFAS standards
Posted: Tue Jan 04, 2022 1:13 pm
by BMU_VMW
For the development of our PFAS method we are looking for some hard(er) to find analytical standards:
Native standards of the following compounds:
- PFPeDA (perfluoropentadecanoic acid)
- MeFBSAA (N-methyl perfluorobutane sulfonamido acetic acid)
Mass-labeled standards of the following compounds:
- ADONA (4.8-dioxa-3H-perfluorononanoate)
- PFECHS (Perfluoroethylcyclohexane sulfonate)
- PFTrDA (perfluorotridecanoic acid)
- PFODA (perfluorooctadecanoic acid)
- PFPeS (perfluoropentane sulfonic acid)
- PFHpS (perfluoroheptane sulfonic acid)
- PFNS (perfluorononane sulfonic acid)
- PFDS (perfluorodecane sulfonic acid)
- PFUnDS (perfluoroundecane sulfonic acid)
- PFDoDS (perfluorododecane sulfonic acid)
- PFTrDS (perfluorotridecane sulfonic acid)
- PFBSA (Perfluorobutylsulphonamide)
- MePFBSA (Methyl-Perfluorobutylsulphonamide)
- MePFBSAA (N-methyl perfluorobutane sulfonamido acetic acid)
- PFHxSA (Perfluorohexanesulfonamide)
- PFOSAA (perfluorooctane sulfonamidoacetic acid)
- 6:2 PAP (Mono[2-(perfluorohexyl)ethyl] Phosphate)
- 8:2 PAP (Mono[2-(perfluorooctyl)ethyl] Phosphate)
I've already checked Wellington and Cambridge Isotopes.
Any advise would be much appreciated.
BMu
Re: (Mass labeled) PFAS standards
Posted: Tue Jan 04, 2022 2:54 pm
by Steve Reimer
I worry that an ever expanding target list + isotope dilution + part per quadrillion reporting levels are going to make these analyses too expensive for general use.
Posted: Tue Jan 04, 2022 6:52 pm
by James_Ball
It already requires pretty much the top end instruments from the manufacturers and the standards are very expensive. I think EPA is beginning to work on methods that don't require a labeled version for every single target, but it is still going to be expensive.
Posted: Wed Jan 05, 2022 8:11 am
by BMU_VMW
I agree, but for now 'the gap' in my labeled standards is just to big so I'm looking for some extra components. Depending on the availabilty and the price I can than make a selection.
