Chemstation excel sheet for multiple samples aligned?
Posted: Fri Dec 10, 2021 2:51 am
We are currently using HPLC Chemstation but am trying to get an excel sheet of all samples, all wavelengths monitored on a single excel or .CSV file. So for example, if we had 50 samples on a run the excel sheet would show retention time and areas for each of the 50 samples after we performed an alignment step. Is this possible? And if so how would we go about this? Is there a report in Chemstation that performs this easily?
