HPLC 3000 Sample is not drawn up from the vial
Posted: Fri Dec 10, 2021 1:52 am
Our lab has a HPLC Ultimate 3000 and I'm having an issue with our autosampler.
I've noticed that our sampler isn't injecting any samples from the sample vials. I visually checked that the needle is moving deep enough to be fully submerged in sample without touching the bottom of the vial, but when the syringe moves down, nothing from the vial is getting drawn out. I tried out different injection volumes, and with high injection volumes, a little bit of stuff does get drawn out, but nowhere near the actual volume that should be getting injected.
I already replaced the needle and the syringe to make sure there wasn't a clog in the pathway but sample is still not drawing up. It doesn't look like to me that the syringe is pulling in air and not liquid when it is supposed to be drawing up samples (although it's kinda hard to tell with clear liquids). I don't find any leaks in the pathway (e.g. from top of the syringe, injection valve, etc.) and I'm confused what else could be going on. Any suggestions?
(Also, unsure if this is related at all, but our syringe makes terrible squeaky noise when it moves up and down to rinse, inject, .... I took out the syringe and pushed the plunger a couple times myself, and it's not the syringe that's making that noise, so I'm assuming it's the hardware that moves the syringe.)
