Problems with ion-exchange chromatography..
Posted: Thu Oct 15, 2009 6:39 am
Hi
I'm trying to purify my protein using ion exchange chromatography (Q-sepharose, 10mM phosphate buffer pH 7.5). Around 70% of my protein comes out in washing fraction, while only the rest elutes with 0.1M NaCl. My guide says a fresh column behaves like that and the protein will bind more as the column grows old. Is that the case? Or any other suggestions?
(Partial purification has been tried already for my protein with DEAE-Sephadex A-50 column, and it has been found to bind at pH 7. So pH should not be the problem, i guess)
