Export peak areas without a calibration in Chemstation
Posted: Thu Dec 02, 2021 6:05 pm
I would like to batch export peak areas of chromatograms without a calibration in Chemstation (B.04.03[16]). I followed the method stated in the two following links;
https://www.chromforum.org/viewtopic.php?t=12276
https://community.agilent.com/technical ... mment-2846
However, no integration results is exported when no calibration is used. In my case, I do not want to use a calibration as I do not know the retention time of the compounds (screening of catalyst with multiple product possible).
Is it possible to export the peak areas without a calibration?
Best regards
Best regards
