unknown injection peak
Posted: Mon Oct 12, 2009 6:04 pm
Hi, I need some help here.
We have Waters Prep HPLC. Each time when the injector is switched, there will be a peak showing up. When I started a run, the software showed waiting for injection, after the injection, there is a peak detected right after the switch is made so the diode array UV VIS will register a wrong baseline. During the run, each time I swtiched the injector back and forth, a peak will show up. Most likely it is not contamination peak, I have clean the injector, and UV VIS detector did not show any distinct feature.
Any suggestions and solution?
Thanks for your help.
