Peak Gaussian Factor
Posted: Tue Nov 16, 2021 6:00 pm
Does anyone other than the EPA use Peak Gaussian Factor to evaluate chromatography?
I have seen software that will calculate either Peak Tailing Factor or Peak Asymmetry automatically, but none that do PGF. For this we still have to print out the chromatogram and physically measure the height and width at 1/2 and 1/10 height to calculate using PGF= 1.83(W half height)/(W tenth height).
Does it really tell you anything different than either of the two other measurements will about the chromatography?
I have just always been curious about this one. Besides, with modern computer integrator software, even the area of tailing peaks is calculated quite accurately.
