Continue to Improve your Titration Process with New Tips and
Posted: Tue Nov 09, 2021 10:54 am
Titration is a precise and widely used method to determine quantitively different compounds in food and beverages to ensure their quality and taste. Limits of impurities, exact contents of specific ingredients or decomposition parameters are set in national and international regulations and can be determined exactly with a titration method.
Join our webinar on 18 November, 2021, and you will learn how to optimize and adapt the titration process to receive correct and comparable results. You will also learn what you have to watch out for to avoid uncertainties and failures in your results whilst getting an insight into our latest innovation of seamless data transfer.
By attending this presentation you will learn...
https://webinar.sepscience.com/form/con ... and-tricks
- about the titration process and what has to be considered
what influences the accuracy of titration results
why and how do we need to determine a titer
tips and tricks for the daily lab work to avoid uncertainties
more about our new titration technology using seamless data transfer from the chemicals to the titrator.
