Problem with GCMS 7890B-5977A
Posted: Fri Nov 05, 2021 1:43 am
Hello everyone'
I have some problems need to help.
Currently, i am using organochlorine pesticides 17 compounds standard and DB 5MS column. When i use Scan mode have peaks of all compound, but with SIM mode at level of concentrations ( 2, 5, 10, 50, 100ppb) peak of compounds: heptachlor, endrin and p,p DDT no see.
I have cleaned ion source, replaced liner, replaced septa. I also cut column but not result.
Please support me. Thank all of you.
