Static-Headspace extraction questions
Posted: Thu Oct 28, 2021 3:44 am
by Hyunsu
Hi, I am recently trying to analyze some volatile compounds by static-headspace GC-MS.
I made standard stock solution using HPLC grade water.
What if I increase equilibration temperature above 100℃ (water boiling point)?
Is it okay to increase the temperature till 85℃, while using water as solvent?
I think it is not appropriate to increase the temperature because of water boiling point, however, my target compound's boiling point is way higher than water's boiling point.
Re: Static-Headspace extraction questions
Posted: Mon Nov 01, 2021 11:22 am
by Peter Apps
Welcome to the forum
What kind of headspace sampler are you using, and what is the boiling point of your target analyte ? If it's boiling point really is way above that of water it may more be suitable for heaspace analysis.
Posted: Tue Nov 02, 2021 7:40 pm
by ingochrist
As long as you analytes evaporate, you don't need to go to their boiling point. My typical HS temperature tends to be 50 - 85C max, otherwise the syringe lasts not very long or you have problems with the solvent, since you over pressurize the vapor phase.
Ingo
Autosampler Guys
