How to prepare n-alkane standards for HS-SPME?
Posted: Fri Oct 15, 2021 9:42 pm
by agao123
HI guys,
I am using HS-SPME for my project and I would like to run n-alkane standards and grob mix in every batch. Does anyone know how I should prepare the n-alkane standras/grob mix standards for HS-SPME? which solvent should I use and what concentration should it be?
Thank you very much in advance for your help!
Re: How to prepare n-alkane standards for HS-SPME?
Posted: Wed Oct 20, 2021 9:57 am
by MK1
Your solvent needs to closely match the matrix of your samples. Anything else changes the partition coefficients & skews the results.
I've found this is a real pain for hydrocarbons in water, the best I can manage is making a concentrate of all the hydrocarbons in the correct ratios then quantitatively transfer a very small portion (~1 µl) of this concentrate to a huge (2l) volumetric & adding water...
Fortunately my samples can contain methanol/ethanol & MTBE so I can add some of these to the hydrocarbon mix while keeping the matrix close to normal.
