Quantification of blank injection
Posted: Fri Oct 15, 2021 11:45 am
Hi i have a question regarding the blank injection for HPLC SEC.
Some guidelines prescribe to use a blank at the beginning to see if there is a stable baseline and no unusual peaks. From what limit can you say there is an unusual peak? is there quantification described in the USP or Ph. Eur. or some other guideline?
All help is welcome, thank you in advance
