basic liquid handling questions
Posted: Wed Sep 30, 2009 4:09 pm
I'm injecting into a microscope flow cell.
My main question is, I've got 3 syringe pumps simultaneously pumping injection loop samples (3 X ~25uL ) into a 7-port manifold (~15uL swept vol). Will these samples mix, or will they output as laminar streams? I wanted to avoid agitation because our biological complexes tend to fall apart with shear force.
Another question, since I can't exactly measure it, does anyone have a rough estimate of how much unintentional mixing/dilution will occur between two inline samples? In other words, if I don't want two samples to mix, how much volume should I introduce between the two? I'm using 0.010 ID PEEK tubing if it matters...
Any other tips for a fluidics newbie?
Sorry for the basic questions (and for not knowing the lingo), and thanks for the help
