Connector for S shaped oxygen and moisture trap
Posted: Fri Oct 01, 2021 1:27 pm
Hello to all. This is very simple question.
I need to replace the brass connector of a Supelco S-shaped Supelpure oxygen and moisture trap. I would like to know if there is a part number for that connector, it connects the 1/4" end of the S shaped supelpure oxygen/moisture trap with a 1/8" copper tubing. I recently bought the trap for my GC-MS and after seeing a huge leak i discovered that a cooper tubing tip was broken and stuck inside the connector. I could not remove it nor get any help from the local representative. I also tried contacting Swagelok (the number in the connector says Swagelok 316-BA9) but i had no luck, the catalog for that number does not match the shape of my connector, maybe it is specifically made for Supelco. I also tried contacting supelco through old emails, but they are no longer active
This is picture to clarify
LInk: https://im.ge/i/TpiY6m
I would need to know if this part is sold, or a contact for getting in touch with a technical person in Supelco
Thank you
Thank you
