GC start up
Posted: Thu Sep 16, 2021 8:58 pm
by GC anxiety
I was asked to create a new method on a GC (New to that process). I got the method set up approved and entered samples into the sequence table. I went to run the sequence (unit said it was ready) and as soon as I hit run, it attempts to run it and then it just says sequence stopping without running anything. I have no idea what is wrong. Please advise.
Re: GC start up
Posted: Fri Sep 17, 2021 1:00 am
by tom jupille
It would help a lot if you mentioned what hardware and software you are using.
Re: GC start up
Posted: Fri Sep 17, 2021 7:09 am
by antonk
I'd rather say: you have sequence line which loads non-existent or broken (with zero analysis time) instrument method.
Re: GC start up
Posted: Mon Sep 20, 2021 8:04 pm
by Peter Apps
Welcome to the forum.
My advice is, post the details of what you are doing, on what instrument, with what method. With the minimum description of the problem you posted, none of us has an idea what is wrong either.
Rod's law: the more you don't tell us, the more we can't help you.
Re: GC start up
Posted: Mon Oct 04, 2021 5:47 pm
by gcgirl27
I love your username and I can relate so much! I now have two years experience and I can promise it gets better.
Were you able to resolve your issue?
