Mephidrone Analysis
Posted: Wed Sep 16, 2009 10:37 am
by Chandresh K. Soni
anybody Knows about the GC Analysis of Mephidrone. If it is possible then on which column.and on which detector.
Please help Me
Posted: Wed Sep 16, 2009 2:42 pm
by chromatographer1
If you are referring to mephedrone, then any silicone column and a FID should work fine as the amino group has an attached methyl functional group. Of course, the chemical should not be in the form of a salt or little volatility will result and there will be poor results by GC.
best wishes,
Rodney George
consultant
Posted: Fri Sep 18, 2009 12:21 pm
Thanks for Your Valuable Sugestion. But i just want specific Column Like DB-17 or Cpsil 5CB with specific method.
Also is there any HPLC Method available. if yes please suggest me the Buffer and stationary phase for this.
