Acquring multiple injections on one chromatogram Empower 2
Posted: Mon Sep 14, 2009 8:59 pm
by Kevin Kelly
Hi Everyone,
Can Empower 2 be programmed to collect one detector signal for 15 minutes while the HPLC is making 15 x 1-minute injections to generate a single chromatogram that has 15 injections in it?
Posted: Wed Sep 16, 2009 2:32 pm
by DR
If you're using an e-SAT/IN and setup 15' run time, then disconnect the start cable after the first injection, you could do it. I don't know why you'd want to though, most injectors take just over a minute to make an injection anyway - the data systems typically take just a fraction of that time to send their data and get ready for the next injection...
