Purity factor threshold
Posted: Sat Sep 12, 2009 4:19 pm
Hi everyone!
I am using an Agilent 1100 with DAD and need to do some peak purity analysis. The issue is when to consider a peak pure based on the purity factor, since i have observed that the calculated threshold limit varies a lot between injections and also between analytes (from 996 to 999).
What criteria should I use to determine an appropiate threshold if I decided to set it manually?
I'd appreciate any advice on this subject...
Thanks!
Dominique
Thanks!
Dominique
