CDC for GC MS/FID
Posted: Fri Aug 06, 2021 5:09 pm
by ofurman
Hello Analytical Chemists community,
I am working on upgrading Agilent 7890B GC-FID  with 5977A MS detector and have a question in regards to software operation system. Does anyone have experience using OpenLAB CDS 2.6 or MassHunter 10 for the GCMS/FID system? Data acquisition, processing, reports for both FID and MS. If so, could you provide feedback on pros and cons. Would you recommend one over another?
Olga
Re: CDC for GC MS/FID
Posted: Thu Aug 12, 2021 4:53 pm
by James_Ball
Olga
Will OpenLab even process the MS data?
MassHunter is good software, but if you have the option to install the MSDChemstation/Enviroquant version F for the data workup I would do that as it will be more similar to the OpenLAB and not require a separate Qual and Quant program open at the same time to view the whole chromatogram when reviewing the Quantative data at the same time.
I have not used OpenLAB except a little on one HPLC so not sure how it works on the MS, but I still like the MS data processing much better than OpenLAB and the old Chemstation B.
Posted: Thu Aug 12, 2021 5:00 pm
by ofurman
James, Thank you. I think it is new option from Agilent to use of OpenLab suite with 2.6CDM on MS.
