Sorry for the little delay, but as promised here is a short introduction to Isotope Dilution Analysis.
We start very simple. Imagine you have a box with an unknown amount of red marbles, all marbles have the same properties (color, size, etc.) and behave
equally. Now you want to determine the number of marbles in the box. One way would be to count all marbles, but you can commit many errors and very time
consuming, especially if you want to know the uncertainty of your counting and have to repeat it several times.
The easiest way to determine the number of red marbles is to resort to a process of "dilution". In order to do that we take a small bag with a known number
of blue marbles. The only difference between the red marbles and the blue marbles is the color. We mix the blue marbles with the red marbles until we have a
homogeneous mixture.
Once we have a homogeneous of red and blue marbles we grab a handful of marbles and count the red marbles and the blue marbles and we calculate the ratio
between them. Since we know the number of blue marbles we added to the box we can easilly calculate the initial amount of red marbles in the box.
It is important to point out that once the mixture is homogeneous, the ratio between red and blue marbles won't change, even if we lose marbles. Furthermore,
the ratio will be constant independent of the total number of marbles we grab, providing always the same result.
If we consider now that the marbles are an element, the red marbles would represent one isotope of the element and the blue marbles another isotope of the
same element. Applying the same principle described above we are already talking about Isotope Dilution Analysis.
Isotope Dilution Analysis is based on the intentional alteration of the isotopic abundances of an element in a sample by adding the same element which
enriched in one of its isotope, called spike, to the sample.
The initial concentration of the element in the sample can be calculated directly by the Isotope Dilution Equation. As you can see in the equation there is
no parameter that depends on the instrumental sensitivity. Further, the only parameter you have to determine experimentaly is the isotope ratio in the
mixture.
As Isotope Dilution Analysis only requires isotope ratio and mass measurements, the advantages compared with other methods become apparent:
As mentioned before, there is no parameter regarding the instrumental sensitivity, therefore any variation of this parameter due to instrumental
instabilities such as signal drift or matrix effects will have no influence in the final value of the element concentration in the sample.
After equilibration, losses of analyte do not affect the accuracy of the analytical result, because the measurand, the mixture isotope ratio, is equal in all
sub-samples of the mixture, therefore there is no need to know the preconcentration or dilution factors of the sample or to take into account any
non-quantitative seperation, derivatization, extraction or evaporation step.
I hope this small introduction to Isotope Dilution Analysis will help you a bit.
