Possible explanations for phantom peaks?
Posted: Mon Aug 24, 2009 11:38 am
Hi Everyone,
Periodically, I see phantom peaks that are uncharacteristic of any other peaks I get when I run a sample. They are very thin and narrow and then FID signal goes to zero before returning to baseline signal.
I started to condition my column, and received a peak, and copied image below. These peaks sometimes occur during a run and then affect the integration due to the signal going to zero after that narrow peak.
Does anyone have experience with this, and can offer an explanation why this is occurring and how I may prevent it. I thought perhaps it may be dust in air settling in detector, or detector may be a bit dirty or there's an overlooked wrong setting of detector. My air is set at 350 ml/min and hydrogen at 35 ml/min, and FID is set at 270 C, so I am not sure what else could cause this problem. Helium carrier is 1.2 ml/min at detector and make-up gas is on at about 10 ml/min.
These peaks do not happen very often, but can ruin a run when they do, and thus can be an annoyance.
Thanks in advance for your help,
Carvone
Carvone
