Preventing Backflash - Acetonitrile
Posted: Sun Aug 23, 2009 7:12 pm
Hoping for suggestions here... I am using a standard splitless liner, 4mm ID x 75mm in length. At the beginning of my GC-MS run, the column head pressure is at 8 psi to generate my 1mL/min constant flow. If I inject acetonitrile into my 250C injector at 8psi, the generated vapor volume is 533uL and my liner volume is only 471uL. Clearly, this poses a problem.
I'd like to know the best way to setup for pulsed splitless injection to get around this issue. If I setup a pulse splitless injection and have the injector pressure at 25psi, the generated vapor volume is now only 305uL, making my choice of liner acceptable. How long do I need to hold the injector pressure at 25psi if my splitless time is 0.75 minutes? Do I need to hold the pressure pulse at 25psi for the entire 0.75 minutes or can I lower it back down to 8psi at say 0.25 minutes? Will lowering it back down to 8psi before the injector vent opens cause backflash or I have already gotten rid of enough solvent vapor during the pulsed 0.25 minutes that I should be "safe"?
Thanks for the advice.
