PPM N2 analysis in pure Krypton
Posted: Sat Aug 22, 2009 5:40 pm
by tigerk2001
Dear sir,
I would like to know what would be the best columns and valve configuration to use for analysis of ppm N2 in pure Krypton.
I tried with a long Molecular Sieve 5A, but both peaks coelute together.
Thanks for your help.
Posted: Sun Aug 23, 2009 12:16 pm
by virtu
Posted: Mon Aug 24, 2009 11:41 pm
by chromatographer1
You can see from the reference a capillary MS5A will not work for ppm analysis of N2 in Kr.
Call Supelco Tech Service and they can tell you how you can do the analysis with 3 feet of packed columns, a 12 inch and a 24 inch.
I don't work for Supelco but I did, and I told them how to do this analysis.
best wishes,
Rodney George
consultant
N2 in Krypton
Posted: Tue Aug 25, 2009 12:33 am
by tigerk2001
Hi Rodney,
Could you please let me know what would be your suggestion of columns and configuration. You gave me some good suggestions in the past that have worked.
I will contact Supelco after to order the necessary parts.
thank you
Posted: Tue Aug 25, 2009 4:59 am
by chromatographer1
The configuration is a two column heart-cut with backflush.
The nitrogen elutes at about 1/4th the time of krypton, about 12 seconds at the beginning of the heart-cut, the cut being about 6 to 12 seconds in width, and then the backflush is operated.
You may be able to do a simple backflush to vent, but I suggest that you don't for best results. If it doesn't give you a high background with your detector, go ahead and do a simple backflush at about 30-35 seconds.
Other details you can discuss with Supelco Technical Service.
How does it feel to get $5000 worth of information for FREE ? :D
best wishes,
Rodney George
unpaid and unemployed consultant
N2 in Krypton
Posted: Wed Aug 26, 2009 1:00 am
by tigerk2001
Thats is a real GC guy!!!
As usual, a lot of accurate details!!! Good ;)
I'll get in contact with Supelco for the right columns.
Do you have a good contact name I could get in contact with in Supelco
thanks again
N2 in krypton
Posted: Wed Aug 26, 2009 1:07 am
by tigerk2001
One more thing for you, Rodney.
Could it be possible to send to my email (dgagne@solutionld.com)your personnal information. Just in case I would need your support in future.
Let me know if it is possible.
many thanks
Dany
Posted: Wed Aug 26, 2009 3:34 pm
by chromatographer1
Dany,
Here is my email address and my home address is:
chromatographer1@aol.com
3501 SE Adams Drive
Blue Springs, Missouri USA 64014
816-600-8290 is my phone
best wishes,
Rodney George
consultant
